Part Number: THVD2429
Hi there
We are using C2000's UART port with 12Mbaud speed. We need to use differential pair transmission so please advise some part numbers for this application.
Hi Alikaan,
What Vcc level do you need to support?
I assume with two wire, you want a half duplex solution?
Any ESD/EFT/Surge requirements?
Do you need to support a certain level of fault protection on the differential pins?
The device you tagged in your post is the THVD2429 which should fit the speed you're looking for. Just curious if there is a reason why that device isn't the right fit for you.
-Bobby
