Part Number: THVD8000
Hi team,
customer found that when mode=1, R will output a low voltage pulse. R is connect to MCU through 51ohm resistor.
The yellow waveform is MODE, green waveform is R pin. Why R will output low when MODE change to 1? Could you pls help with this case? Thanks!
Rayna
