TLIN1021A-Q1: When we tested LIN1021A-Q1, we found that there would be an error frame
Part Number: TLIN1021A-Q1
Could you please help us check? When we tested LIN1021A-Q1, we found that there would be an error frame when undervoltage was started, do you have any suggestions?
Figure 1 is the schematic design;
Figure 2 shows the waveform when the undervoltage is started.
Figure 3 shows the normal startup waveform
  • Hi Songhao,
    We recommend LIN pulled up to VSUP but not INH. As LIN is internally pulled up to VSUP in normal mode, it is not expected to maintain normal communication in a undervoltage condition.
    What was the VSUP value when that error occurred? Can you include the capture of VSUP on the same plot?
    Sean
