Part Number: DP83TD510E
Hi Team,
We are developing APL isolators that are upstream termination is APL field switches and downstream termination is APL field devices. Would like to use DP83TD510E, there are a few questions to ask, please help to comments, thanks.
- Is the PHY of the two APLs able to be connected directly?
- Can we use a digital isolator between the PHYs?
- If the APL switch support PoDL, and upstream side of the isolator we designed do not need to draw power from the switch, could these two ports be connected directly?
- Could APL isolators power downstream devices at a fixed voltage and current, how to realize this usage? If SCCP is not supported, will communication be affected?
