Part Number: SN65HVD62
dears,
it is my customer first time to use SN65HVD62, would you please help to double check their schematics?
thanks a lot!
dears,
thanks a lot!
Hi Andrew,
From what I can see, everything looks okay to me....
One minor check for the customer:
Can you verify if the customer has a 1k pull up resistor on the Syncout pin? I only see it goes to another net. This pin is an open drain output so an external pull up resistor is required on this pin. Datasheet recommends 1k to ensure output levels.
-Bobby
