Part Number: TUSB211
I received some samples, but can not know which is pin one from the IC chip surface.
Can any one share the pin one dot explanation for this chip-TUSB211AIRWBR
Hi Viola,
Pin one should be at the bottom left in this case. It looks like there is a dot trying to illustrate that. However, you can also look at the bottom of the device at the pins, and see which pin is slanted at one of the corners:
Pin 1 is indicated on the pins by the pin with the slanted corner.
Please let me know if you have any other questions.
Ryan
Hi Viola,
Do you know what is these block dots for, very confusing if these are not pin 1 illustration.
I can't say I know why those are there, I don't believe they are typically. I can check with the devices we have here under a scope and see if I notice the same, but I believe these aren't important.
Ryan
