Part Number: TCAN1043-Q1
1) Apply wake-up pattern to transceivers
2) INH pin activate
3) MCU on
4) Enable STB_N, EN signal to specify the exact operating mode of the transceiver from the MCU
1. Yes, after a wake up event is read on the CAN bus or through the wake pin, the device enters the Standby Mode, which turns INH high. Typically the INH pin is connected to a PMIC enable pin. However, the transceiver does not turn on immediately. There is a small delay due to the PMIC turning on and supplying VCC (and VIO if setup this way) to the transceiver.
2. This sequence of events is correct. To clarify however, this assumes that VSUP is powered on and the device is in Sleep mode initially.
3. Section 8.4.9 of the datasheet further describes the INH pin.
Please let me know if you have any further questions.
Ethan
