SN888C: SN888C RS485 Transceivers Technical support
Part Number: SN888C
    We are using SN888C IC for RS485 Interface in our project.
    Controller is interfaced with PC using RS485 converter, rarely communication isn't working. When we swapped wire of A and B, Working fine on that time.
   After device power up on particular period, It's not working. Again, we swapped the A and B pin and its working properly. Same way, it's going on continuously.
   we thought the problem due to bus polarity automatic detection in this IC and can't find the root cause of the problem.
  Please find our device circuit design in the attachment. We are using the same design for both Rs485 Master and slave mode.
  Kindly refer and provide your guidance which is very helpful for us.
Thanks and Regards,
Dhanush.D,
