Part Number: TCAN2451-Q1
Hello team,
If the RSTN stuck to high, what is the reaction for this device? I cannot find this in the datasheet.
Thanks!
Daniel Wang
Hello team,
Thanks!
Daniel Wang
Hi Daniel,
Who is your customer- I am asking because I have the same exact question from a direct question on E2E from a customer and I want to see if this is the same group asking the question so we don't have multiple threads on the same topic.
In case this is for a different customer please see below:
If the nRST is high then the device won't restart when the nRST pin is asserted low.
The device only drives nRST low when the device is in restart mode - so if devices downstream rely on the output low signal from this pin during restart mode they won't see the signal.
Ultimately - if the nRST is stuck high -the restart functionality cannot be accessed through the nRST pin but most other device operation should be okay if only nRST pin is impacted.
Parker Dodson
Hello Parker,
My customer is Conti, I am not sure if they posted this question in E2E already, I will share the reply with them.
Thanks!
Daniel Wang
Hi Daniel,
I missed a detail in my last reply - the watchdog timer may not start correctly which could cause the device state machine and modes to become unreliable. This is because the t_initWD timer starts at the low to high transition of the nRST pin - so if the device can't control that FET there could be unexpected behavior depending on how the watchdog is configured.
Parker Dodson
