Part Number: TIOL111
Other Parts Discussed in Thread: TIOL112
Hi Team,
I have got a question regarding the current limit of the C/Q pin No. 8, which can be used bidirectional and beside the IO-Link data stream as a standard IO in a second mode.
A current limit can be set by a resistor at pin No. 6 „ILIM_ADJ“ and in the data sheet a current is described in the section „Driver Output (CQ)“, which can be delivered by the C/Q pin (source mode of the C/Q pin), respecting the ajusted current limit of course which I have set by a 47k resistor.
Now my special question is the ability of the C/Q pin for consuming a current (sink mode of the C/Q pin) especially for the standard IO mode where the C/Q pin is used as a digital input.
Is in this case the same current limit for source mode valid for the sinking mode too and does the adjusted current limit by resistor at pin 6 act as well for a sinking current at C/Q pin?
For this case of use I did not find a hint in the data sheet, so far... Maybe somebody can provide me some further information.
Thanks a lot for hints in advance.
