TCAL6416R: IO States while in Reset
Part Number: TCAL6416R
The datasheet indicates that the registers are sticky for this part. I'm curious what this means for the IO states if the device is in reset. Consider the following sequence:
  • When the device is first powered on, all IO's are configured as inputs by default.
  • The host configures an IO to be an output driven high
  • If the reset pin is driven and held low (active), does the IO stay as an output-high, or does it reset to an input?
  • When the reset is released, I understand that the IO will revert to the previous state which is output-high. Is that correct?
Ryan
  • Hi Ryan,
    The IO should stay as an output-high. The /RESET pin resets the I2C state machine.
    To reset the internal registers and therefore reset the IO back to an input, you would need to power cycle or conduct a general call software reset.
    This is the idea of "sticky registers."
    Tyler
