TCA9555: Pull-up resistors by default?
Part Number: TCA9555
Other Parts Discussed in Thread: TCA9535
I just would like to ask for clarification - when the ports of TCA9555 are configured as inputs, pull-up resistors on those pins are enabled by default, am I right? So, when I read status of those pins, it will be high, till they are not driven low by external signal?
In the datasheet of TCA9555 is written: The TCA9555 is identical to the TCA9535, except for the inclusion of the internal I/O pull-up resistor, which pulls the I/O to a default high when configured as an input and undriven.
What does word undriven means in sentence above?
Many thanks, Kind regards, Dejan.
  • "Undriven" means that they are not driven by an external signal.
    As shown in figure 23, the pull-up is always active.
  • Hi Dejan,
    Yes you are correct here.
    Yes this is correct.
    As Clemens suggested already, an external signal by another device in the system.
    Tyler
