hi TI,
I would like to integrate the DP83TG721S-Q1 with the TDA4AL MCU RTOS code base. We are currently using PDK version 10_00_00_27.
I noticed that the DP83TG721 driver appears to be the same as the DP83TG720 driver in TI's GitHub repository: TI Ethernet Software.
However, when following the guide (Enet PHY Driver Integration) to add a new Ethernet PHY and driver, I encountered some issues.
It seems that the DP83TG721 driver code differs from the TDA4AL MCU RTOS PDK (Enet module).
Could you please clarify:
- Is there any other driver version available that is compatible with the TDA4AL MCU RTOS PDK (Enet module)?
- Is there any demo code or reference implementation specifically for the DP83TG721S-Q1 with the TDA4AL MCU RTOS?
Thank you for your assistance.
