Part Number: DP83848Q-Q1
Hello Team,
We are using DP83848Q-Q1 IC ,operated for RMII interface.
We have some query regarding the pins,
1.For Pin 28 , X1 : RMII Reference Clock 50MHz ,this clock will be provided my our MPU .What should be the status of the Pin X2 ?
2.Wnat should be the configuration of the Pin 21 , CLK_OUT ?Should we assign test point and keep floating or Pullup pull down is required ?
3.What is the life cycle (EOL : End of Life) for this IC ,DP83848Q-Q1 ?
Tirthal
