Part Number: DP83826E
Hello team,
Does DP83826E support IEC 61000-4-2 ESD: ±8 kV?
It was found on the 1st page of the datasheet, but couldn't find it on the ESD Rating section.
Kei Kuwahara
Hello team,
Kei Kuwahara
Hello Kuwahara-san,
The ESD specification you have listed is a system level functional test which relies on many other factors including the PHY. The ESD section within the PHY datasheet is for a different ESD test which talks about tolerances that the device can directly withstand before damage may occur.
Sincerely,
Gerome
Hello Gerome-san,
Thank you for your quick reply!
On the datasheet of DP83822, IEC 61000-4-2 ESD: ±8 kV is listed on ESD Ratings table.
This means that DP83822 supports IEC 61000-4-2 ESD: ±8 kV on device level, while DP83826 does not?
Kei Kuwahara
What is the requirement from specification standpoint? In general, DP83822 is our most robust device out of the DP8382x family.
Sincerely,
Gerome
