Part Number: MAX232E
I would like you to confirm specification of minimum value of Isc.
According to datasheet, typical value of this spec is defined as "+/-10mA".
However there is no description about min spec. Could you disclose min spec of Isc ?
The background of this question is customer will try to estimate bandwidth vs drive output current following by below application note (Figure 4)
https://www.ti.com/lit/an/slla037a/slla037a.pdf
So, if you can not disclose min spec of Isc, it is OK to show how we can consider load cap and bandwidth from other aspect(parameter).
