DS320PR810: can it support sata protocal?
Part Number: DS320PR810
Hi team,
Can DS320PR810 work in sata application?
    Yes, the DS320PR810 device can support SATA applications (and most AC coupled interfaces).
    Please note that this device provides maximum CTLE gain at 16GHz (PCIe 5.0) data rates, so the CTLE gain applied by the DS320PR810 at SATA data rates (0.75GHz, 1.5GHz, 3GHz) will inherently be a bit lower due to the shape of the device's CTLE gain curve.
    Note that depending on your application, you may require higher CTLE gain for SATA data rates. Here are some additional redriver devices which support SATA for your reference: https://www.ti.com/interface/pcie-sas-sata/products.html#1389=SATA3&
    David
