AFE7950EVM: error executing devInit.py through Latte (AFE79xx GUI)
Part Number: AFE7950EVM
we are working on Jsdb data transfer from AFE7950EVM to KCU105 evaluation board.
we are trying to program EVM clocking through Latte (AFE79xx GUI) and executing following commands
1. Run setup.py - this command executed successfully
2. Run devInit.py - this command is not executed successfully.
please find the attached screenshot for detailed error log
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/138/Screenshot-_2800_5_2900_.png .
we have restarted the FPGA and repeated the experiment and still issue exists.
please let us know the solution.
  • Hi Manjula,
    It seems like the image is not coming through very clear so I am not able to see the exact error you are reporting. Can you share the text reported?
    Is the error you are seeing 'Reset the FPGA and try again'? If so then this is expected when connected to a dev kit as the Latte GUI is not used to program the FPGA. When using a FPGA dev kit you can ignore this error and continue.
    David Chaparro
