Part Number: TCAL9539-Q1
Hi expert,
Have a nice day!
About TCAL9539-Q1, what are the I/O states during I2C error or other fault cases? Is that Hi-Z, low or other?
Best Wishes,
Leo Ma
Hi expert,
Have a nice day!
Best Wishes,
Leo Ma
The I²C protocol itself does not have any error-checking mechanism.
The device is a simple state machine that reacts to the signals on the SCL and SDA pins. When the signals are corrupted, then it is possible that commands are acted on by the wrong (or no) device, or that wrong values are read from or written to the wrong register.
To reduce the risk of errors, isolate the SCL/SDA lines from each other and from other traces with high-frequency signals/noise, and use a high pull-up current (typically 3 mA).
Hi Tyler, Clemens,
Thank s for your replies.
IN Datasheet 8.1, "The system controller can reset the device in the event of a timeout or other improper operation by asserting a low on the RESET input pin or by cycling the power to the VCC pin and causing a power-on reset (POR). "
What I want to know is what are the states of P00-P07 and P10-P17 before "asserting a low on the RESET input pin"? Such as Hi-Z, low or other?
Best Wishes,
Leo Ma
