THVD8000: Application issues.
Expert 2380 points
Part Number: THVD8000
Hi Team,
PartNumber: THVD8000.
Will there be conflicts and interference when there are multiple different power carrier communication schemes for a power line (such as power modem router products+THVD8000 products)?
If the Power Cat router continues to transmit and receive network data at full capacity, can the THVD8000 still work normally?
  • Hi Reed,
    The answer is likely yes, there will be interference. While I am not familiar with the other power line communication schemes and how they transmit, the THVD8000 uses on-off keying (OOK) modulation over the power lines. This will likely conflict with the other communication methods over the power line.
    Ethan
