Part Number: SN65DSI83
Other Parts Discussed in Thread: DS90UB941AS-Q1
Hello TI Team,
I am looking for a solution to connect a 24 bit RGB display with a resolution of 480x272 and a pixel clock/DCLK of typ. 9 MHz (8-12 MHz) to a MIPI-DSI interface or to a SN65DSI83.
I have 3 questions:
- If I have read it correctly from the data sheet, the SN65DSI83 can only work from a pixel clock of 25 MHz. Is this correct and is the module therefore incompatible with the display?
- Do you know the minimum pixel clock that a MIPI-DSI interface can provide?
- Can you suggest a solution how I can connect the display to a MIPI-DSI interface?
Many thanks for your support!
Dirk
