DP83867E: Ethernet splitter
Part Number: DP83867E
Hello
I plan to use the DP83867E device for managing ethernet interface.
However, I need to physically split the incoming ethernet into two link. One needs to be full duplex and the other one, just a receiver (listener) - link.
Do you have any suggestion on how to do such thing? what device could I use? Both links needs to operate at the same time...
Thanks.
Sebastien
  • Hi Sebastien,
    If possible could you draw a block diagram for further clarification on your requirement. May I ask what is the speed requirement you are looking for?
    DP83867 is not a switch, most likely you cannot send signals at the same time.
    Hillman Lin
