DP83867IR: Required decoupling capacitance
Part Number: DP83867IR
Pages 120-121 of the datasheet show quite a lot of decoupling capacitors used on the part, generally a combination of 1uF and 0.1uF on each with some added 10uF and 0.01uF caps as well.  Page 121 is showing a total of 30 decoupling capacitors per chip.
Is this conservative, and if so is it known if a smaller decoupling bank can be used?  For example, can some of the larger capacitors be eliminated?
  • Hi Farron,
    The variety of decoupling capacitors are to filter a wider range of noise on the supply rails.
    The recommendation will depend on the amount of noise you expect on these rails from the supplies & environment.
    Smaller decoupling banks could be used if noise is not a significant concern in the application.
    Thank you,
    Evan
