DP83822I: DP83822 Magnetics interface
Part Number: DP83822I
Other Parts Discussed in Thread: DP83822EVM, DP83848C, DP83848Q-Q1, DP83849C, DP83848I, DP83849I, DP83848YB, DP83849ID, DP83848M, DP83848T, DP83849IF, DP83620, DP83848H, DP83848J, DP83630, DP83848K, DP83640, DP83848VYB
I'm currently using one board with two DP83822 PHYs that is plugged to the small carrier board with the connector and the Magnetics.
I want to use multiple of these boards in series (EtherCAT) and I'm wondering if I can remove the Magnetics block between PCB1 & PCB2 and PCB2 & PCB3 ?
Thanks!
Milos
  • Hi Milos,
    It's possible to operate DP83822 without magnetics/transformer on MDI lines.
    For more details on this, please refer to this application report:
    https://ti.com/lit/an/snla088a/snla088a.pdf
    DP83822EVM also has options for transformer-less operation, for an additional reference.
    Thank you,
    Evan
  • Hi Evan,
    I have a few questions:
    1. The link you posted seems to be applicable only to:
    DP83848C DP83848Q-Q1
    DP83848I DP83849C
    DP83848YB DP83849I
    DP83848M DP83849ID
    DP83848T DP83849IF
    DP83848H DP83620
    DP83848J DP83630
    DP83848K DP83640
    DP83848VYB
    I don't see DP83822 here, can you confirm that this application note would work for DP83822?
    2. If I understand correctly, I just need to add one capacitor in series (33nF, 100V) and to remove 1.8V from the pin 14 on the PHY side (AVD pin)? Should I leave that pin floating or connect it to GND?
    3. Are the pull up resistors on the PHY side necessary? If yes, what value should I use? Also, what value for the capacitance between PHY's 3V3 and GND should be used?
    Thanks!
    Milos
  • Hi Milos,
    Similar principle in application report applies to DP83822.
    Please refer to DP83822EVM schematics here ("3.2 Analog Front-End Schematic"):
    https://www.ti.com/lit/ug/snlu179/snlu179.pdf
    For transformer-less operation, T2 is DNP'd, and C47 - C50 are populated.
    Pull-up resistors are required on MDI lines (50 ohm).
    Please let me know if the schematic clarifies the required network for this.
    Thank you,
    Evan
