Part Number: TCA39306-Q1
Other Parts Discussed in Thread: SN74LVC2G66, SN74LVC2G125-Q1, TCA9517-Q1, SN74LVC1G126-Q1
How to use the TCA39306-Q1 device as a UART switch (also as a kind of buffer)? I understand that the TCA39306-Q1 is typically used for voltage level translation for the I2C/I3C bus, but I am specifically interested in how to implement it in a UART communication setup to effectively switch and buffer the signal line.
Please provide guidance on how to configure the TCA39306-Q1 for this use case? Additionally, I would greatly appreciate it if you could share or point me to an application schematic showing the correct connections for using the TCA39306-Q1 as a UART switch/buffer.
Thank you.
