Part Number: THVD2450V
For the THVD2450V device, what are the min, typical, max values of the integrated pull-down resistor on the DE pin? On the RE# pin? On the D pin?
Thanks!
Thanks!
The electrical characteristics show that the input current (the sum of resistor and leakage currents) is at most 5 µA, so the minimum resistor value is VIO / 5 µA. Other characteristics are not specified. If you want to increase the noise margin, add a stronger resistor.
