Part Number: TS3USB30E
Other Parts Discussed in Thread: SN74LVC2G66
Hello support team,
I'm looking at using the TS3USB30EDGSR to disable a UART connection to host while the host is being programmed, or if the UART device is powered off to save power.
I only have one IO pin left on the MCU and I wanted to check I can pull both S and H high with pull-up to disable bus by default? The truth table does not show if S can be high with OE and still disconnect.
Or I could pull S to ground permanently and just pull OE low to enable the bus as required?
Anders
