Part Number: DP83TG720S-Q1
Hello team,
My customer found an abnormal case, can you help share your insights?
Due to the case happened in end user side, my customer can only read the logs, and found 0x1834 register show the device was working under the slave mode (originally Master), and link up also failed, after resetting the issue was settled down, and now it is hard to repeat the issue.
Thanks!
Daniel Wang
