DP83867IR: Programmable Gain Register
Part Number: DP83867IR
Hello support team,
currently there are compliance measurements performed. The product is utilizing the TI DP83867 PHY.
The measurements had been performed, but gets a "FAIL" result with the default settings. But the measurement can be done with "PASS" if  using the Programmable Gain Register. Unfortunately, TI records in the Revision History state that this register has been “removed” from the document. And now, of course, there is uncertainty as to whether the setting may be made? And whether it can lead to other problems when using the Programmable Gain Register to increase the signal amplitude…
DP83867IR/CR Robust, High Immunity 10/100/1000 Ethernet Physical Layer Transceiver datasheet (Rev. I)
Best regards
Carsten Rebmann
