TCAN4550-Q1: No message at low temperatures
Part Number: TCAN4550-Q1
hi expert,
my customer use TCAN4550-Q1, now they find No message at low temperatures in TCAN4550-Q1, they are not sure if tcan4550-q1 have problem.
their system is NFC--MCU--CAN, NFC use SPI transfer the signal to mcu, and mcu use SPI transfer signal to tcan4550-q1, at last tcan4550-q1 transfer the signal to other ECU. so they do the low temp test in every device. they Spray a quick refrigerant in NFC/MCU/CAN, and get the SPI signal , you can review the SPI signal, could you help see any abnormal in any device SPI.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/2025_2D00_02_2D00_08_5F00_10_2D00_58_2D00_13_2800_normal-temp_09FF_.kvdathttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/2025_2D00_02_2D00_08_5F00_11_2D00_00_2D00_46_08FF_Spray-a-quick-refrigerant-in-NFC-about-3-minutes_09FF_.kvdathttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/2025_2D00_02_2D00_08_5F00_11_2D00_02_2D00_23_08FFB755_NFC_2900_.kvdathttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/2025_2D00_02_2D00_08_5F00_11_2D00_08_2D00_03_2800_Spray-a-quick-refrigerant-in-MCU_2900_.kvdathttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/2025_2D00_02_2D00_08_5F00_11_2D00_25_2D00_01_08FF_Spray-a-quick-refrigerant-in-CAN_2900_.kvdat
  • Hi Colt,
    I'm unable to open the files you've attached.  Can you provide them in some other format?
    I don't know what their circuit configuration looks like, and whether they are using a crystal or not. However if they are using a crystal, the shot of cold spray could cause a clock disruption that would cause communication issues.
    Jonathan
