Part Number: LP-MSPM0L2228
Hi sir,
I didn't find the API to configure GPIO pin as output low, could you help guide me how to do it?
Edware
Hi sir,
Edware
Hi Diego,
I think DL_GPIO_clearPins() is just for NOT output, right? My concern is that if our HW tight one GPIO pin to pull-up resistor, how could I set the pin to low. Can DL_GPIO_clearPins() do it?
Edware
Hi Edware,
When you set the Pin low, it will basically connected to VSS. So even if you put a pull-up resistor on it, as long as the I/O is used as an output, it will be low. For more information, please see the Userguide's Figure 9-1. Superset IO Slice.
Diego Abad
