TPD4E05U06-Q1: Questions on material and certification of this part-
Part Number: TPD4E05U06-Q1
Hi all, can you help with the below questions-
  1. Can you provide the IATF 16949 certificate(s)?
  2. Can you confirm if this part has bimetallic wire bonding to the IC die?  The PPAP states the wire bond material as Au. It then states item #11 Die metallization material(s) as AlCu.
  3. If this part does have bimetallic wire bonding to the IC die, does TI perform any purple plague mitigation?
