DP83869HM: Using upstream driver with RGMII-1000BASE-X mode
Part Number: DP83869HM
I've recently been testing the DP83869HM device using the upstreamed Linux driver. The upstream version of this driver enables auto-negotiation in 1000Base-X mode, while the datasheet for this part indicates that this is not supported:
>In fiber mode, the speed is not decided through auto-negotiation. Both sides of the link must be configured to the same operating speed.
In my testing, I have not seen the device work properly in this mode with auto-negotiation enabled.
I also note that the out of tree driver has auto-negotiation disabled: https://github.com/TexasInstruments/ti-ethernet-software/blob/main/linux_drivers/dp83869.c
What is the current recommended driver for use with 1000Base-X? If it is the out of tree driver, are there any plans to fix this in the upstream version?
Thanks.
  • Hi Matt,
    We recommend using our out of tree GitHub drivers with our Ethernet PHYs as these are the most up to date. Can you test with the GitHub driver you've linked and see whether this resolves your issue?
    We plan to fix this in the kernel (upstream) drivers, however there is currently no set date for this change.
    Shane
