TCAN1044-Q1: IIL and IIH of STB pin
Part Number: TCAN1044-Q1
Hi team,
There used to be IIH and IIL specification in EE table as below for STB pin, but it seems the specification
was dropped from the datasheet between rev A to rev B.
Could you please advise why this parameter was dropped?
I need to know the amount of pull up value to calculate external components value.
regards,
  • Hi Shinji,
    This is most likely due to spec being non-critical I.e., leakage is so low that it will not essentially impact external component selection. Hence, you may use previous values with no concerns, thanks.
    Michael.
