hi team,
Could you suggest a suitable EQ level? Customer would like to change the AEQ_min and AEQ_max to improve the link robustness and avoid EQ lock to a wrong level.
We are running the MAP to get some guidance, at the same time, pls check are there any 93x/95x insertion loss vs EQ suggestion table available to make a comprehensive decision of EQ setting.
- 935+936 sync mode with 4Gbps fpd-rate
- EE is E-mirror application with 10m coax cable
- Insertion loss test result as below -15db@2Gbps
Dongbao
