DS90UB913A-Q1: Can transformaers be used to interface between DS90UB913A and DS90UB914
Part Number: DS90UB913A-Q1
Hi Team,
Please advise me on my question bellow.
Capacitors are used to connect the DS90UB913A output and the DS90UB914 input.
Question1:  Are there any use cases transformers are used instead of the capacitors?
Question2:  If so, can you let me know the recommended transformers and common mode filter for this application.
Question3:  If you have evaluated transformer coupling, can I share the test report?
The reason why I came up these questions is that, TI’s app note says transformer coupling
is more robust against noise than the capacitive coupling.
https://www.ti.com/lit/an/snla420a/snla420a.pdf
MIta
