Part Number: DS96F175MQML-SP
I am using an RS485 bus with data and clock at 5 Mbps.
I need to perform a worst-case analysis on the timing, to verify the margin between data and clock.
Do you have any data on the relative timing delays of 2 receivers in the same package?
Or can I assume half the worse-case delay as the difference between receivers, given that they're on the same process and at the same temperature?
Many thanks,
Michael
