DS90UB913A-Q1: FPD-Link III interface
Part Number: DS90UB913A-Q1
Hello
I am designing a circuit using a serializer (DS90UB913A) and a deserializer (DS90UB914A).
I am inputting a 27MHz PCLK, data, and synchronization signal to the serializer side.
However, the PCLK output from the deserializer is 13.5MHz, and the synchronization signal is similar to the data and is different.
What do you think is the cause?
Please advise.
    Thank you for reaching out. Are you talking about the imager's PCLK? Is the imager's PCLK being used as the device's reference clock or is an external clock being fed to the device? What mode are you operating in? A 27MHz PCLK is on the lower end of supported frequencies, and the devices would need to be operating in 12bit LF mode. Can you explain what you mean by the synchronization signal being similar to the data? If possible, screenshots or images of the signals would be helpful.
