DP83TD510E: DP83TD510E datasheet error?
Part Number: DP83TD510E
I'm planning to connect the DP83TD510ERHBR to an MCU via MII.
In the DP83TD510E datasheet, it states that the RX_DV/CRS_DV pin is Strap5, with a default function of 25 MHz clock output, and when set to 1, it functions as LED_1.
However, isn't this actually the CLKOUT/LED_1 pin rather than the RX_DV/CRS_DV pin?
