THVD8000: MODE Resistor
Part Number: THVD8000
Hi experts,
May I know what's the reason we recommend to use 2Mohm for MODE? What would be acceptable range or any concern what if changing to other value?
Allan
  • Allan,
    We don't recommend you use a 2M resistor on the mode pin. The datasheet states there is a 2M ohm resistor on the mode pin (internal to the device).
    You should use a value much smaller than 2M to correctly bias the pin. The smaller the value, the stronger the biasing but the more leakage there will be. I would probably say 10k would be fine.
    -Bobby
