TDP0604: IBIS AMI model incomplete?
Part Number: TDP0604
Hi!
I am using the TDP0604 IBIS AMI model which is available on the website. I am interfacing this model with Ansys tools.
The .ibs file refers to these files for redriver.
Redriver_Signal_Path_x64.dll
Redriver_Signal_Path.ami
However, the files which are in the folder are labelled as  RX_Signal_Path.ami and RX_Signal_Path_x64.dll. To muddle it further, there is a Redriver_Signal_Path_x64.so file but no dll counterpart.
Is this a naming issue or are the contents of the AMI folder wrong?
Thank you
  • Hi Aneeq,
    The model naming may be incorrect here, thanks for pointing this out.
    Let me look into this and get back to you.
    Shane
  • Hi Aneeq,
    Here are the correct files for the ami model:
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/Redriver_5F00_Signal_5F00_Path.ami
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/Redriver_5F00_Signal_5F00_Path_5F00_x64.dll
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/Redriver_5F00_Signal_5F00_Path_5F00_x64.so
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/rx_5F00_term.s4p
    TDP0604.ibs
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/tdp0604_5F00_IBIS_5F00_AMI_5F00_wrk.7zads
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/Thru.ami
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/Thru_5F00_x64.dll
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/Thru_5F00_x64.so
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/tx_5F00_term_5F00_100.s4p
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/tx_5F00_term_5F00_300.s4p
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/tx_5F00_term_5F00_NT.s4p
    Users_Guide_snlu315.pdf
    I hope this helps, let me know if you have any questions.
    Shane
