Part Number: DP83869HM
Other Parts Discussed in Thread: DP83869, DP83869EVM
I have 3 questions regarding the design of the DP83869HMRGZ.
1.Due to the requirements of the connected system, we need to change the communication mode from SGMII to Copper to 1000Base-X to 1000Base-T.
In the current SGMII configuration, AC-coupling capacitors are installed on the SIN, SIP, SOP, and SON lines.
When switching to the 1000Base-X to 1000Base-T mode, is it necessary to remove these capacitors?
2.Also, I apologize for the broad nature of the question, but as we are considering modifying the attached schematic to support the 1000Base-X to 1000Base-T mode,
please let us know if there are any additional changes required. (We are not planning to change auto-negotiation settings, so we are not considering switching the LED pins.)
Changing RX_D3 to Low
Connecting JTAG_TDI to the SFP_RX_LOS pin of the SFP connector (J4)
3.Regarding the JTAG_TDI pin, the DP83869 Schematic Design Review Checklist you previously provided states that no connection is required.
However, on your company's evaluation board(DP83869EVM), it is connected with a pull-down to GND.
In this case, is a pull-down resistor necessary?
schematic
We appreciate your support and thank you in advance.
