SN65DSI83: SN65DSI83ZXHR
Part Number: SN65DSI83
When am Trying to Create the Schematic Symbol and Footprint of IC SN65DSI83ZXHR that Pins are not Matching with Image what you Shared in the Data Sheet Image what you Given for  Pin Configuration and Functions its Looks Like Bottom view but you mentioned as top View Please Check it once and Conform the Right one for Reference i will attached the  data Sheet link
www.ti.com/.../sn65dsi83.pdf
  • Hi Rakesh,
    I am really apologized if I don't understood your question. I did a quick sanity check that the top down view of the diagram and pin description matched. Did you create your symbol and footprint? Did you use the CAD from us? If you want, I can get the BXL file for you so that you can translate into your CAD environment.
    Aaron
