Part Number: SN65LVELT23
I want o convert LVDS @1.03GHZ to sinewave at 50 ohms load.
I need some suggestions. Please.
Hi Santhibhushan,
As I mentioned in my reply to your other post, 1GHz far exceeds the ratings for our LVDS receivers. If you have more information about your application we may be able to identify a device that works for you.
Jack
Thanks for your reply.
I need 1030MHz pure sine wave signal @50 ohms load. But I did not find any such oscillators with sine wave output.
I found one crystal oscillator which can produce 1030MHz with LDVS output.
So, I need to convert this LVDS to Sinewave.
Please suggest any solution.
What are the required common-mode and peak-to-peak voltages at the 50 Ω input?
LVDS is a digital signal. How pure must the sine wave be?
Hi Santhibhushan,
To confirm, you need to convert an LVDS clock signal to single ended sinewave, or is the sinewave to be differential as well? What are your jitter and common-mode requirements?
Jack
