DS90UB941AS-Q1: DS90UB681 compatible part
Part Number: DS90UB941AS-Q1
Other Parts Discussed in Thread: DS90UB981-Q1, ALP
Dear Team,
Due to DS90UB681 FPD Link chipset unavailability.
Can you suggest similar chipset that support DS90UB681 with deserializer compatibility ? DS90UB941AS-Q1 suitable or not ? SW side drive support available ?
Let me know if you require more information
Thanks & Regards,
Vishal Mistry
  • Hi Vishal,
    Can you elaborate on the application?
    The following serializers can be used to support DS90UB681 functionality:
    • DS90UB941AS-Q1
    • DS90UB981-Q1
    The corresponding deserializer will depend on your video output. Can you specify what output video protocol you require?
    We have SW driver support for our products using ALP with a script generation tool and GUI support.
    Please download both ALP and ALP-Profile-Update from the site  - https://www.ti.com/tool/ALP
    Additionally, here is the driver for the 98x family:
     https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/ALP_5F00_98XPROFILE_5F00_UPDATE_5F00_v03-_2800_1_2900_.exe
    Ragav Subramanian
  • Dear Ragav,
    I have verified the current configuration of the serializer and deserializer, and the system is driving a Full HD display using the DSI interface over an FPD-Link.
    • Serializer: DS90UB681
    • Deserializer: DS90UB688RUR
    Could you please confirm alternative part (DS90UB981RTDTQ1) whether this configuration is suitable for our application and deserializer ?
    Looking forward to your response.
    Thank & Regards,
    Vishal Mistry
  • Dear Ragav
    Do you require more information ? Please let us know if anything require
  • Hi Vishal,
    If the video application is supported with x688, then using the x988 will be a sufficient replacement for the system.
    Just to confirm, can you clarify your video resolution settings?
    Ragav Subramanian
  • Dear Ragav,
    Required Video output is Full HD 1920 x 1080 pixels display using the DSI interface.
    Can you suggest Serializer full part number compatible with deserializer: DS90UB688RUR ?
    For Reference kindly find attached block diagram for understand application.
    Waiting for your response.
    Thanks & Regards,
    Vishal Mistry
  • Hi Vishal,
    Assuming 24-bit color resolution and 60Hz refresh rate - yes, DS90UB688RUR is compatible with application
    Serializers compatible with DSI and your given application:
    Ragav Subramanian
  • Thank you for response
