Part Number: DP83822I
We have used DP83822I in our design. The eye pattern is not matching with 802.3 template. Need suggestions to improve the same.
Should we try changing Rbias? Change decaps on transformer?
Vp-p swing as per Electrical characteristics for 10BaseTe is 1.76V. But LDCTRL register mentions Swing can be 3.7V also. Is this correct?
What is the correct setting to be in LDCTRL register for 100 & 10mpbs ?
Can the 49.9m Termination resistor be 0402 (0.062W) if the any of the swing voltage is considered for 10Base-Te?
