Part Number: DS90LV018A
Hi exparts,
In the circuit I designed, I did not follow the precaution that "the differential input terminals should be opened when not in use", and the output level changed irregularly from "H to L" to "H" to "L". Since an isolation transformer was connected to the IC, the differential input terminals were connected through the transformer.
However, not all ICs experienced this kind of output change, and some ICs had a fixed output level of "H".
Could you tell me what makes this defference? I suspect that the variation in offset voltage may be involved.
Let me know if you need more info.
Hiromu
