DP83822I: The ethernet reset Data required
Part Number: DP83822I
We are using SNx4LVC08A for interfacing micro, Ethernet and FLASH for power on reset,  the R=330 and C=0.22u is used , WD_Reset, RST_GPIO and Ethernet_uC are from controller. Is this RC sufficient for for power on as follows: first  Flash and then ethernet. Reference circuit below:
for DP83822IRHBR we need following data:
1. The time delay from VCC to reset? min and max values
    Can you please expand your original question to add further clarification? If Reset is unconnected, it is expected that the pin will rise with VDDIO ramp due to internal PU resistor. Else, this pin will be an input to the device, so there is no min/max characterization data.
    Sincerely,
    Gerome
