Part Number: MAX3232
Hi Susan,
Thanks for reaching out about this device difference. There are only 2 PCNs between 2021 and 2023: the one you found about the device marking and another describes the MAX3232IDR obsoletion. Although the obsoletion PCN was released in 2022, the last day devices were shipped was August 2023, so this device looks to be in that last batch. Note that this device was obsoleted to push towards the improved ESD version (MAX3232EIDR), nothing is faulty about your particular device.
I have reached out to our design team to see if they know why there is a difference.
The datasheet does mention that in 2021 the thermal parameters were updated. So this might indicate an internal change. However, since there is no specific PCN or change in the datasheet about the device functionality, there will be no functional changes.
I will update you once I get a response from our internal team.
Ethan
Hi Susan,
Thanks for your patience. I recently got a response, and there are no functional changes to the device.
Ethan
