Part Number: TL16C452
I'm seeking guidance on the best practices for the long-term storage of Texas Instruments moisture-sensitive components (such as the part number of the E2E thread title). These components are typically supplied in IPC/JEDEC J-STD-033 compliant Moisture Barrier Bags (MBBs) with desiccant and a Humidity Indicator Card (HIC).
My primary question is regarding the handling of these sealed MBBs during extended storage periods (e.g., several years):
- Is it sufficient to store these factory-sealed MBBs unopened, periodically inspecting only the bag's external seal integrity, and checking the HIC just after opening the bag for use in our production process?
- Or, does TI recommend a schedule for periodically opening these MBBs to inspect the HIC, potentially replace the desiccant and HIC, and then reseal the bag, even if the components have not yet been required for production?
I've reviewed TI's application report: Component Reliability After Long-Term Storage. The document states: "Standard packing materials (bags, desiccant, and humidity cards) are robust for a 32 month storage period that can be extended by repacking with fresh materials. Packing materials designed for long term storage are effective for more than five years."
This statement implies that for storage durations potentially exceeding 32 months, repacking with fresh materials might be necessary. However, establishing a best practice that involves routinely opening original Texas Instruments packaging for such maintenance seems to conflict with the general preference for preserving original packaging integrity for as long as possible.
Could TI provide a definitive recommendation on how to balance these considerations for its moisture-sensitive components?
Thank you very much in advance
